Old 14-Dec-2013, 8:22 AM   #2
0 NM(dB) is the target figure for reliable reception , 30 feet antenna height above level open ground , no obstructions , with a dipole 'tuned' for the channel of reception.
'Tuned' means the length of the metal reception elements resonate at the , channel/frequency , of transmission and reception.
It is better to have some elbow room for signal strength flucuations and non perfect signal paths , of +10 NM(dB) , and stronger signal strengths are better.
However Many locations have reliable reception with , 0 NM(dB) and on down to Minus-10 NM(dB) and a few locations , a little lower -12 to -15 however those low numbers are the exception reception situation.
Antenna Gain helps bring all numbers up.
For reception at your location the NM(dB) numbers will be above +10.
WMPN-DT , WMAU-DT , W45AA-D , are all the same PBS , http://wn.wikipedia.org/wiki/Mississ...c_Broadcasting , so no requirement to receive , WMAU-DT channel 15 or W45AA-D channel 45.
WRBJ channel 34 is now TBN Trinity Broadcasting.
http://en.wikipedia.org/wiki/WRBJ-TV.
The CW has moved to , WJTV channel 12 CBS and CW and Antenna Tv.
http://en.wikipedia.org/wiki/WJTV.
So I recommend install a , http://www.antennacraft.net , HBU11 , aimed at about 5 degree magnetic compass direction.
If not interested in reception of TBN then aim the HBU11 at about 348 degree magnetic compass direction.
Disconnect and Remove All amplifiers.
Recommend run all New coax outside , RG6 coax with the Compression type connectors on the ends of the coax.
And replace other outside , connectors , couplers , coax ground block , and other etc. .
Disconnect and Remove the splitter situation you have now.
Recommend test reception with 1 Tv connected , No splitters. No amplifiers.
To Prove reception run a New continues length of coax through a open door or window , direct to 1 Tv.
(((Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.)))
For 2 Tv's connected use a , HFS-2D , Holland Electronics 2 way splitter. No amplifier.
For 3 Tv's connected use a , HFS-3D , Holland Electronics 3 way splitter. No amplifier.
For 4 Tv's connected use a , HFS-4D , Holland Electronics 4 way splitter. No amplifier.
Buy the , HFS-2D , HFS-3D , HFS-4D , Holland Electronics splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
If signal strength becomes a little weak in the system with a splitter , then install a
Winegard , LNA-100 'Boost' , antenna system amplifier Before the splitter.
http://www.antennacraft.net.
http://www.solidsignal.com.
http://www.amazon.com.
I see your next post and Yes a HBU22 antenna will be Ok.
Last edited by teleview; 16-Dec-2013 at 2:50 AM. Reason: Clarify information and typos.
