Old 13-Dec-2013, 5:48 AM   #7
Ok here is a way to do it , and receive All the Networks that are receivable.
PBS
NBC
ABC
CBS
The CW
MyNetwork
Me-Tv
This Tv
FOX
MOVIES Movie Channel
Weather and News channels
Antenna system #1.
For reception of , WCBY-TV channel 5 - NBC and The CW.
And WJHL-TV channel 11 - CBS and Me-Tv.
And WEMT channel 38 - FOX and MOVIES.
And UNC channel 42 - PBS.
Install the HDB8X UHF antenna aimed at about 27 degree magnetic compass direction.
Install a AntennaCraft CS600 antenna aimed at about 25 degree magnetic compass direction.
Connecte the HDB8X and the CS600 , together with a , UHF/VHF diplexer/combiner , EU385CF-1s , buy at , http://www.solidsignal.com
Connect a , http://www.channelmasterstore.com , CM7778 preamplifier , to the output of the UHF/VHF combiner so that both antennas are amplified.
If more then 1 Tv is connected use a , Holland Electronics , HFS-2D 2 way splitter or HFS-3D 3 way splitter.
Buy the HFS-2D and HFS-3D splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
________________________________________________________________________________ _____
Antenna system #2.
For reception of , WLOS channel 13 - ABC and MyNetwork.
And UNC channel 35 - PBS.
And W02AT-D channel 2 = WSPA-TV - CBS and Me-Tv.
And W09AS channel 9 = WYFF-DT - NBC and This Tv.
install a , http://www.antennacraft.net , HD850 antenna aimed at 190 degree magnetic compass direction.
Most likely No antenna system amplifier required for up to 3 Tv's connected.
Use a HFS-2D 2 way splitter for 2 Tv's connected and a HFS-3D 3 way splitter for 3 Tv's connected.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Antenna systems 1 and 2 are Separate Antenna Systems All The Way To Each Tv Location.
At each Tv location a , Remote Control A/B antenna switch , will select antenna systems 1 and 2.
http://www.mcmelectronics.com , #32-4425 , remote control A/B antenna switch.
If you have to , you can put the antennas close together on one antenna mast.
And you can put mast pipe sections together to make the mast higher.
You can also use these , cross clamps , to install 2 masts on 1 mast.
http://www.ronard.com/700.html.
And you can also put up 2 separate antenna mounts.
http://www.solidsignal.com.
http://www.amazon.com
http://www.antennacraft.net.
http://www.channelmasterstore.com.
http://www.mcmelectronics.com.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
Last edited by teleview; 13-Dec-2013 at 10:18 PM. Reason: Clarify information and typos.
