Old 12-Dec-2013, 8:55 PM   #5
For reception of the Digital Boadcast Tv stations/channels in the Tvfool Current Plus Pending Applications Included Channel List down to and reaching out for , WNYB and WBBZ .
Remove and discard the old antenna.
Remove and discard All outside , coax , twin lead , couplers , connectors , splitters and etc. .
Install All New.
Install a , www.winegarddirect.com , HD7698P antenna aimed at about 180 degree magnetic compass direction.
Here is how to aim antenna , www.kyes.com/antenna/pointing/pointing.html
The first 7 Tv stations channels of the Tvfool channel list are 4.5 miles away and very strong signal strength.
So I recommend do not install a preamplifier at the antenna.
>Test reception first< , with no antenna system amplifier , run a New Continues length of coax that has the Compression type connectors on the ends of the coax , run the coax direct to 1 Tv through a open door or window.
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channels scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Install the HD7698P antenna on the rotor in such a manner that what rotation the rotor does have will turn the HD7698P antenna will rotate back and forth , south west , south , south east.
Receiving the 2 weak Tv stations , WNYB , WBBZ , is the goal.
The other Tv stations above the 2 weak Tv stations in the tvfool channel list will be received with out moving the antenna once the 2 weak Tv stations are received and the antenna then will be on one position with out moving the antenna.
As to a antenna system amplifier , after the , >Test reception first< .
If a antenna system amplifier is required , install a , Winegard - LNA-100 'Boost' indoor amplifier , before , any splitters , so the signal is amplified before being split.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.amazon.ca.
http://www.amazon.com.
Last edited by teleview; 13-Dec-2013 at 1:30 AM. Reason: Clarify information and typos.
