Old 12-Dec-2013, 8:01 PM   #4
day7a1
http://www.tvfool.com/?option=com_wr...46aeeb820b7081
I realized after my post that the ERP for 10 is a little higher than for 8, but the NM is a little lower.
I rent, so I really don't see putting up a 10 foot pole on the roof. There is a satellite dish mount I may be able to repurpose though.
Will a FM trap do anything for VHF-Hi? I thought it was mostly for 2-6, but interference would explain the drastic changes in reception.
I already tested the signal with and without an amp...it's significantly better with, but I don't think a stronger one will help...you can't amplify darkness. I'm pretty sure the one I have is overcoming the cable run, which is it's purpose, right?
day7a1 is offline   Reply With Quote
