Originally Posted by Comenius
Curious, why would the DB8e be a better choice than their C4?
I presume the 'their' in, "... their C4..." referrers to 'Antennas Direct'... The forward beam of the C4 is fixed and it's peak gain is spec'd at 5 dB less than the DB8e. The DB8e can be adjusted to provide either a narrow forward beam or wider. In this application, I think the DB8e will need to be adjusted to a moderately wide forward beam to optimize reception from the two main groups of signals.
(Note that I am suggesting the new DB8e, not the older DB8.)
Cheers
Reason: sp.
