Old 11-Dec-2013, 5:56 AM   #3
I recommend the , http://www.antennacraft.net HBU33 antenna.
Aimed at about 16 degree magnetic compass direction , here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Signal strengths at your location are strong to moderate.
A antenna system amplifier will most likely not be required.
For reception of the , Digital Broadcast Tv stations/channels in the , Digital Current Plus Pending Applications Channel List down to and including , WNCT-TV Real VHF channel 10 , virtual number (9.1) , CBS
www.solidsignal.com or www.hollandelectronics.com
www.solidsignal.com
www.amazon.com
Recommend Test reception buy connecting a single continues run of coax from the antenna direct to 1 Tv , no couplers , no splitters , no amplifiers , no etc. .
The Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Broadcast Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Digital Tv Setup Menu and select ~ DTV Channels ~ Broadcast Channels ~ Antenna Channels ~ Air Channels ~.
Scan for channels.
Last edited by teleview; 12-Dec-2013 at 3:18 PM. Reason: Clarify information and typos.
