Old 11-Dec-2013, 12:03 AM   #1
dogggis
Considering a bigger antenna, thoughts?
I'm considering getting a bigger antenna and want to know if it will get me what I want.
First my info:
Signal Map: http://www.tvfool.com/?option=com_wr...46ae8394a025af
Current antenna: http://www.amazon.com/RCA-ANT751-Qua.../dp/B0024R4B5C
Its on top of my 2 story roof. I estimate at least 25 off the ground.
This is the pre-amp I'm using and it totally makes a difference: http://www.amazon.com/Winegard-ANWI8.../dp/B001DFZ5EW
I live about 25 miles southeast of Seattle.
Right now I get channels:
KWPX-TV 33.1
KZJO 22.1 (Joe TV)
KCPQ-DT 13.1 (Fox)
KCTS-DT 9.1 (PBS)
KIRO 7.1 (CBS)
KCPQ 22 (FOX)
KIRO 51 (CBS)
KUNS 51.1 (Univision)
I can pick up these other three channels, which I'd really love to have, but I have to turn my antenna just a little bit, and end up losing channels 7 and 13 above.
KING-DT 5.1 (NBC)
KOMO 38 (4.1) (ABC)
KONG-DT 31 (16.1) (NBC)
Most of the channels that I do get have a pretty weak signal and will sometimes get too weak if its raining.
I'd also rather not have to use a rotor to get all the channels if possible.
I'm thinking of getting this DB8 antenna:
http://www.amazon.com/Terrestrial-Di.../dp/B000EHWCDW
My Questions:
I'm hoping that since its multi-directional that I'll be able to pick up all the channels without having to use a rotor. Thoughts?
I'm also hoping that the signal will come in stronger and not die out due to weather.
Do you think I would need a separate VHF antenna?
Thanks for your help!
dogggis is offline   Reply With Quote
