Old 9-Dec-2013, 2:43 AM   #3
For reception of the Digital Broadcast Tv stations/channels in the Green reception zone.
Install a , www.channelmasterstore.com , CM5018 antenna in the Attic aimed at about 245 degree magnetic compass direction.
Here is how to aim antennas, www.kyes.com/antenna/pointing/pointing.html
No antenna system amplifier is required for 1 or 2 Tv's connected.
If Non Reliable Reception Situations Happen that are Not Resolvable with Antenna Aim and Location Adjustments in the Attic.
Move the CM5018 antenna to above the Peak of the Roof of such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , West South West and East.
Buy the HFS-2D splitter at , www.solidsignal.com , or , www.hollandelectronics.com .
www.solidsignal.com
www.amazon.com
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for channels.
Attics and insides of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflections Bouncing All Around.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own attic roof and building.
Last edited by teleview; 5-Jan-2014 at 7:55 AM. Reason: Clarify information and typos.
