Old 8-Dec-2013, 3:03 AM   #6
jayjr1105
Is the frame of the receptacle connected to the electrical service ground? I have to ask... the previous owner here failed to connect any ground wire to several of the receptacles they installed.
If you're actually connected to a #12 or #14 AWG 'equipment grounding conductor', you should have protection from contact with power. Ie. you could hope to trip a 15, 20 or even 30 Amp breaker if the coax came in contact with a branch circuit. And you would expect that this would drain static off the antenna system.
Yes, It's a 20 amp circuit (#12 wire) with ground. I personally wired it. I worked for an electrician for a couple years and can properly wire most residential stuff.
jayjr1105 is offline   Reply With Quote
