Old 7-Dec-2013, 4:11 AM   #5
Originally Posted by Damathon View Post
...On combining antennas using the TVPRAMP1R - would I expect to see my uhf signal improve if I set it to split and only plug the 4228 into uhf?
If your only problem is excessive loss due to cable length and splitter(s), a preamplifier can be expected to help. If you have poor signal quality at the antenna (there is more to signal quality than just strength), an amplifier will simply drive a stronger version of the low quality signal at the tuner.
If you have only only one antenna connected to the TVPRAMP1R, set the UHF/VHF switch to the "COMMON" position. Also, set the FM trap to "ON".
http://www.voxxintlcorp.com/docs/com...PRAMP1R_OM.pdf
