Old 5-Dec-2013, 9:27 PM   #2
For reception of
WVTA-DT , REAL UHF Tv channel 24.1-2-3-4 , virtual number (x) , PBS Channels.
http://en.wikipedia.org/wiki/Vermont_Public_Television
WNNE-DT, REAL UHF Tv channel 25.1-2 , virtual number (3.1-2) , NBC and Me-Tv.
http://en.wikipedia.org/wiki/WNNE
W28DQ-D , UHF Tv channel 28 , If the station is on the Air.
WYCU-LD , REAL UHF Tv channel 26.1-2-3-4 , virtual number (3.1-2-3-4) , Outside Tv and Tuff Tv and Reto Tv and PBJ . http://www.rabbitears.info/market.ph...lity_id=189163.
WCAX-DT , REAL UHF Tv channel 22.1-2 , virtual number (3.1-2) , CBS and News/Weather.
http://en.wikipedia.org/wiki/WCAX-TV.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , West , North West , North .
Install a Antennas Direct , DB4e , UHF antenna aimed at about 325 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
For reception of
WMUR-TV , REAL VHF Tv high band channel 9.1-2 , virtual number (9.1-2) , ABC and Me-Tv .
http://en.wikipedia.org/wiki/WMUR-TV.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the direction of , South East .
Install a , AntennaCraft , Y10-7-13 , VHF high band antenna aimed at about 154 degree magnetic compass direction.
On the same antenna mast , put the DB4e above and the Y10-7-13 below the DB4e , separate the antennas by about 3 feet on the same mast.
Connect the DB4e antenna and the Y10-7-13 antenna together with a , EU385CF-1s , diplexer/combiner .
Connect the DB4e to the UHF connection.
Connect the Y10-7-13 to the VHF connection.
Connect a Channel Master CM7778 preamplifier to the remaining connection of the combiner and both antennas will be amplified.
For 3 Tv's connected use a , Holland Electronics , HFS-3 D , 3 way splitter.
Buy the , HFS splitters at , www.solidsignal.com
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
www.antennacraft.net
www.ronard.com/909911.html
www.ronard.com/34424560.html
Use the , ronard(4560) eave antenna mount.
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so buildings and other obstructions including your own roof and building.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflecting Tv signals bouncing all around.
The Best Pratice is to install the antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for channels.
Last edited by teleview; 7-Dec-2013 at 3:12 PM. Reason: Clarify information and typos.
