Old 5-Dec-2013, 9:02 PM   #5
Originally Posted by stell27@nc.rr.com View Post
The station still shows up on the database when I enter my address.
The TVFool database has the data in it from the FCC's licensing database, such as it is. If there's a license or a construction permit issued, then it shows up in the TVFool database. If there is an error or omission in the FCC data, a common enough occurrence, then the same will be reflected in the TVFool data unless Andy goes in and manually changes it. With 4000-5000 non-full power stations in the country, that isn't likely to happen.
