I would think that a good equalizer would treat a weaker second copy of the same signal as multipath and make use of the power in both signals.
It doesn't work that way. The equalizer doesn't see the individual multi-path signals as discrete entities, it only sees the sum or difference.
You'd have to design and build a true diversity receiver to do what you've suggested.
