Old 5-Dec-2013, 10:43 AM   #4
Test reception with the , CM4228 , above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East , South East , South .
Test reception without and with the amplifiers.
Aim the CM4228 antenna at about 162 degree magnetic compass direction.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception and so do buildings and other obstructions including your own roof and building.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflecting signals bouncing all around.
The Best Pratice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Digital Broadcast Tv Tuners can develop -Digital Glitches - that are not cleared out with simple channel scans.
To clear the tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 7-Dec-2013 at 4:38 PM. Reason: Clarify information and typos.
