Old 5-Dec-2013, 2:38 AM   #8
Based on the block level Tvfool report.
I see the updated Tvfool report and the recommendation is the same.
The following is a recommendation for reception with 1 Tv antenna aimed on 1 direction.
Please note that my recommendation is not the final and only way to go about reception , others here at Tvfool will also have recommendations.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North West , West , South West , North East .
Install a , www.antennacraft.net , HBU44 antenna aimed at about 300 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
A antenna system amplifier will most likely not be required for 1 or 2 Tv's connected.
Buy the HFS splitters at , www.solidsignl.com .
Here are some strong and sturdy antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , www.ronard.com .
www.solidsignal.com
www.amazon.com
www.ronard.com
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channels scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels , Air Channels ~ in the Tv Setup Menu.
Scan for channels.
As always, trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
The Best Practices is to install the HBU44 at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 5-Dec-2013 at 5:14 AM. Reason: Clarify information and typos.
