A bit of an update. As suggested, I tried adding one and then two more Radio Shack FM Traps. No improvement over just using a single one.
If I want to keep everything in my attic and improve NBC (VHF 11), is my next step to invest in a dedicated Hi-VHF antenna?
Is there a meaningful difference between the Hi-VHF performance of the Antennacraft Y10713 and Y5713 and the Antennas Direct C5?
Am I correct that I can connect any of the Hi-VHF antennas to the the VHF port of the C2V? Do I need to remove the dipoles from the C2V, leave them extended, or fold them down? And I should leave the single FM Trap after the C2V as it is right now so that it continues to filter both UHF and VHF?
