Old 4-Dec-2013, 7:35 PM   #5
The Digital Broadcast Tv stations/channels at your location are Weak to Very Weak Signal Strength at your location.
If the Small antenna and mounting location that you choose produces few channels and unreliable reception.
Then install a Handsome and Beautiful , www.antennacraft.net , HBU44 antenna above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South West , West , North West.
Aim the HBU44 antenna at about 245 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antennas/pointing/pointing.html
Use a Real and Actual magnetic compass to aim the antenna.
Install a , www.channelmasterstore.com , CM7778 preamplifier.
Buy the HFS splitters at , www.solidsignal.com .
Here are some strong and sturdy antenna mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.solidsignal.com , or buy from , www.ronard.com .
www.solidsignal.com
www.amazon.com
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Some and not all of the Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflecting signals bouncing all around.
The Best Pratice is install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 4-Dec-2013 at 7:54 PM. Reason: Clarify information and typos.
