Old 4-Dec-2013, 7:15 AM   #3
Install a , www.antennacraft.net , HBU11 or HBU11K , above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North East , West , South West.
Aim the HBU11 / K , at about 32 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html .
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Digital Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna channels ~ Air Channels ~.
Scan for channels.
Digital Broadcast Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear the tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf .
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception and so do buildings and other obstructions including your own roof and building.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflections signals bouncing all around.
The Best Practice is to install the HBU11 /K , at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
www.solidsignal.com
www.amazon.com
Test reception Without a antenna system amplifier.
A antenna system amplifier will most likely not be required because of strong signal strengths of Tv stations at your location.
Last edited by teleview; 7-Dec-2013 at 11:53 PM. Reason: Clarify information and typos.
