Two significant issues, the two signal, WSBW, real CH-31 and WQPX, real CH-32 are blocked by trees to the NE. Your antenna is low and indoors.
I would opt for an ANT-751R, above the roof, pointed toward 32° per a compass. The stronger signals from the opposite direction would be received through the rear of the antenna. I would not install any amplifier unless you were splitting to many TVs and driving unusually long cable runs.
I'd also go as high as safety and practicality allow, if it would result in making the WPQX path LOS or at least 1-Edge.
Reason: go high
