Ok, the plot thickens. After more experimentation, here is what i found out: As I move the antenna up the mast, VHF channel signal improves, and UHF channel signal declines. When I move the antenna down the mast, the opposite occurs. So, at the top of the mast, channel 6 is perfect, at the bottom, channel 29 is perfect. Right now I kind of have it in the middle, trying to optimize both, but neither are perfect. Any thoughts on this or how i can exploit this or can anyone explain it? Perhaps I should mount the C2V, by itself, at the top of the mast and the DB4e at the bottom?
