Old 2-Dec-2013, 10:37 PM   #27
If the mast is supported by attachment to the building, I wouldn't bother burying any of it in the ground. I would consider supporting the mast on a concrete pier block or similar solid material that would prevent the mast from sinking into soft soil.
Even if the mast is buried in the earth, I would still connect the mast to your electrical service ground, using #10 AWG copper. The idea is to bond (note) the mast to the same ground system that serves the rest of your electrical system. Then I would also install a grounding block for the coax... http://forum.tvfool.com/showthread.php?t=901 (post #20)
(note) The NEC defines Bonded (Bonding). "Connected to establish electrical continuity and conductivity."
