Old 2-Dec-2013, 10:13 PM   #16
Flint Ridge
Junior Member Wannabe
Is all RG11 cable equal? I know it's not, but what should I look for?
Can get a spool of Belden 1523A-010, Duobond RII Shielded rather cheap locally gathering dust. It's PVC coated and I do not see where it is UV rated.
Spent way too much time on here reading stuff from GroundUrMast and Teleview. Must say if you have not read GroundUrMast's, "Application and Misapplication of Amplifiers" http://forum.tvfool.com/showthread.php?t=1514, then you should, fun and informative.
So, I want to eliminate "noise" as best I can as I work toward solving a channel issue.
And I finally got an actual compass so I need to go double check my hand pointing to best signal.
Flint Ridge is offline   Reply With Quote
