Old 16-Nov-2010, 6:50 PM   #2
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Time for a good VHF-UHF antenna mounted on your roof with a rotator. You need a real one this time, with VHF as well as UHF elements, and I would recommend using a Winegard HD-7082P and a Channel Master 9521a rotator, or an AntennaCraft TDP-2 rotator.
You have a local channel 5, a low-band VHF channel, which is the student-run station at University of Florida available to you, which is why I suggested an antenna with low-band capability.
With this antenna-rotator combination, you should see all the stations down to W07BP-D on your TVFool.com listing, but, remember that you'll have to turn the antenna towards the different stations. I think you are going to be very pleased with the results!
