Old 1-Dec-2013, 9:02 PM   #24
strav
Hi all,
I've got the CM5016 up and honestly I'm a bit disappointed with the results so far. I'm detecting far fewer stations than I was with the FL6550A or even with the temporary DIY bowtie antenna I had put up temporarily (http://www.diytvantennas.com/bowtie.php). To be fair, the stations that I am getting with the CM5016 are *solid* while the other antennas I was using detected more stations but wouldn't necessarily lock or could have quality issues with the video.
I'm thinking it would be beneficial to raise the antenna higher. Right now it's sitting on a 5' mast off the peak of my roof. A glance around at the other houses shows most of the antennas on at least a 10' mast. That would be enough to clear most of the trees in the immediate area.
The question now is should I keep the CM5016 and hope the taller mast helps out or return it and go with the Antennas Direct DB4e and Antennacraft Y5713 suggestion from GroundUrMast. The cost isn't much of a concern as it'll be paid for within a couple of months of cancelling cable. Opinions anyone?
Thanks for all the help!
strav is offline   Reply With Quote
