Thanks GroundUrmast!
Since I had the HD stacker here I decided to install it using a wineguard gable mount and a 10 ft mast just to see "what" channels I could get.
I aimed the antenna using the signal meter on the Tivoand ended up at about 32 degree magnetic north
If I think I can get more channels (with the guide data from tribune media) I will go your route GroundUrmast.
All the channels I do get are 2 dash(2-1) one ect, would this be the same as 2 point one(2.1)?
Also the scan did pick up a bunch of higher listed channels 31,49,51 and 63, these all have guide data (TIVO HD) but even after picking them up on scan there was no signal. Will your suggestion fix this GroundUrmast?
Here is usable channels I got after channel scan using my TivoHD.
a lot of duplicates with no guide data.
CBS/2-1, KREM-DT Frequency 12, signal strength 89 DT? DIGITAL??
CBS/2-1, KREM-DT Frequency 51, signal strength 91
ABC/4-1, KXLY-DT Frequency 12, signal strength 89
ABC/4-1, KXLY-DT Frequency 51, signal strength 90
NBC/6-1, KHQ-DT Frequency 12, signal strength 88
NBC/6-1, KHQ-DT Frequency 51, signal strength 88
PBS/7-1, KSPS-DT Frequency 10, signal strength 69
PBS/7-1, KSPS-DT Frequency 16, signal strength 77
PBS/7-1, KSPS-HD Frequency 49, signal strength 77 HD? High Def?
PBS/7-2, KSPS-WO Frequency 49, signal strength 77 WO?
PBS/7-3, KSPS-CR Frequency 49, signal strength 77 CR?
FOX/13-1 K14BFD Frequency 14, signal strength 89
???/28-1, KAYU-DT Frequency 12, signal strength 88
???/28-1, KAYU-DT Frequency 51, signal strength 91
47-1, KWCC-LD Frequency 10, signal strength 70 Local Channel Guide
47-1, KWCC-LD Frequency 16, signal strength 77
47-2, KWCC-LD Frequency 10, signal strength 69
47-1, KWCC-LD Frequency 16, signal strength 78 Local Channel Guide
47-3 TVW, Frequency 10, signal strength 69 Local
47-3 TVW, Frequency 16, signal strength 77 Local
