Old 16-Nov-2010, 6:19 PM   #1
Esteban
Better reception - antenna recomendation ??
http://www.tvfool.com/?option=com_wr...81a34a76362cf1
Above isthe link to my location. There seem to be many stations available but most are a distance away.
My present situation.;
I have an older, non HD Tv, & a cheap convertor box. I have a, amplified outdoor antenna , pointed due N. that has been out there for years. It is a " Wineguard Bowtie- type , " that does fairly well. I can receive , at most, about 6 channels. I can get a good signal on a couple of channels [ 20-1 & 20-2 ] & the others are borderline signals. These are 9-1,,, 28-1,,,28-2,, & 51-1 . I can get on the roof & turn it & pick up 2 more channels, but that is it. There isn't a rotary motor on it. For the area, I am on a higher elevation, about 125 ft above sea level , & the antenna is 15 off the ground above my house, & there are only a few trees , nearby.
I would like to be able to improve the reception on the channels & get, plus possibly pick up some more . What do you recommend ??
Thanks in advance !!
Esteban is offline   Reply With Quote
