Old 1-Dec-2013, 7:04 AM   #3
Where is the antenna located , attic or above the roof??
Or some where else??
Aim the antenna at about 170 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install a New matching transformer (balun) to the antenna and connect a NEW continues length of coax to the matching transformer , run the New continues length of coax , direct to 1 Tv.
The Digital Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels.
The , ATSC aka 8VSB channels.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~. ATSC aka 8VSB .
Also do not channel scan for Analog Tv channels.
Last edited by teleview; 1-Dec-2013 at 7:09 AM. Reason: Clarify information and typos.
