Old 1-Dec-2013, 6:56 AM   #15
StephanieS
Yes, did you do a tuner rescan?
I hear the frustration in your voice. Remember, TV antenna installs are sort of a black art. There are many variables at play, sometimes you have to work through them to find the solution you want.
An idea is that I might try another receiver other than the RCA 7". If your indoor TV is your final destination, I would conduct my testing on that TV as it's tuner is the one that will be used daily.
I am leery or recommending a preamp to you. The RCA TVPRAMP1R serves me well and has a good tolerance for strong signals. In my situation, I have 65 db signals off to my side, while you have 71 db. You are also much closer than I am to your strong signals transmitters.
I would:
A. Test on indoor TV, doing a complete digital channel rescan with only the Y5-7-13 patchd into the TV.
Do this rescan each time you fiddle with it.
B. If A unsuccessful, order and test RCA TVPRAMP1R on Y5-7-13
C. If A and B unsuccessful order Y10-7-13. Test Y10-7-13 with and without preamp to determine best reception situation.
You are seeing other signals on the Y5-7-13 yes?
Originally Posted by dexxa View Post
No preamp installed pointed the antenna at 203 magnetic and NO mutiple tv setup yet. just pointing at WTOL location my rca 7inch tv has signal meter and i am able to tune to channel 11 but snowy so i turned the antenna little back and forth to see if i was able to get it..but nothing... Also antenna is on top of roof about 20ft high Also tested it at night to see NOTHING! I am running cable 50ft and also went over to a field near me open space nothing around and still not a damn thing spent all day on this project.
