I have to wonder if the 3036 is aimed correctly... Just to be sure, the front of the antenna is the short group of elements (the UHF section) and at the rear are the longer VHF elements that sweep forward. The antenna should be pointing toward Seattle, about 180° per a real compass.
How high is the antenna? Is it blocked by trees or hidden in an attic?
Is the cable new or salvaged?
