Old 1-Dec-2013, 5:28 AM   #11
For reception of ,
KING -NBC
KIRO -CBS
KOMO -ABC
KCTS -PBS
KZJO -MyNetwork
KCPQ -FOX
KSTW -CW
KWPX -ION
And other Tv stations/channels.
For Reliable Reception , I recommend a antenna at no less then 25 feet above ground. And higher will be better.
Install the antenna above the roof in such a manner that roof and building are not , obstructing , impeding , blocking , reception in the directions of reception.
The directions of reception are , South West , South , South East , North West .
www.ronard.com/Tripods%200703/4712.html
At www.solidsignal.com , the part number is (RON4712-50-10) .
www.ronard.com/909911.html
Use the , ronard (911) , 5 foot tripod antenna mount.
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard (2212) , ronard (2218) , ronard(2224) .
Buy the ronard antenna mounts at , www.solidsignal.com , or buy from , www.ronard.com .
Install a www.antennacraft.net , HBU55 antenna with a www.channelmasterstore.com , CM7778 preamplifier.
Aim the HBU55 antenna at about 184 degree magnetic compass direction.
Here is how to aim antenna , www.kyes.com/antenna/pointing/pointing.html
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Buy the HFS splitters at , www.solidsignal.com .
www.solidsignal.com
www.amazon.com
www.antennacrtaft.net
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building in the directions of reception.
The Directions of reception at your location are , South West, South , South East , North West.
The Best Pratice is to install antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 1-Dec-2013 at 2:02 PM. Reason: Clarify information and typos.
