Old 16-Nov-2010, 1:03 PM   #5
No static at all
No static at all's Avatar
You can add a middle section to the 91XG that will provide a small gain increase, but more importantly can help tame multipath if that is a problem. You should be getting all of the yellow coded stations with the set-up you have.
I would start with raising/lowering the antenna a few inches to see if that improves RF 24. Did you aim the antenna with a compass? If so, did you try any additional aim tweaking? Are you using a separate antenna for ABC 7?
