Old 30-Nov-2013, 10:34 PM   #2
Before giving up on the CM-2016, please try 'testing' reception outdoors. An antenna stuck indoors has less desired signal to work with and is closer to sources of interference being produced by equipment in the home. The interference produced in most homes tends to affect VHF channels more than the UHF channels.
If you have a gable end, you may be able to mount an eve/gable bracket and short mast... avoiding the hazards of working on the roof.
