Old 30-Nov-2013, 10:06 PM   #3
esbushiell
Thanks for the response with the antenna recommendation. Do you see any reason that the antenna I currently have (Audiovox ANT751R DGTL) wouldn't work?
I'm very frustrated because based on the distance, it seems that I should be able to get 2.1 without any issue but I can't pick it up at all. The same with 7.1 and 7.2. Should I invest in a preamp?
esbushiell is offline   Reply With Quote
