Old 30-Nov-2013, 6:03 AM   #8
As a Test temporary install the ANT751 antenna above the peak of the roof on such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of , North West , North , North East.
Aim the ANT751 antenna at about 310 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception witha Tv antenna and so do buildings and other obstructions in the directions of reception including your own roof and house in the directions of reception.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
The Current Tv channels that are being Transmitted and Received in the , USA , Canada , Mexico , are
UHF band channels 14 thru 51.
Your location has recevable Tv channels in the VHF high band and UHF band.
Tvfool channel list shows the , Real channels , and , (virt) virtual numbers.
An example is ,
WEHT , Real VHF high band channel 7 , (virt) virtual number (25.1) ABC .
The VHF high band channels , 7 and 9 , are subject to interference sources more then the other VHF high band channels.
For improved reception put the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Last edited by teleview; 30-Nov-2013 at 6:08 AM. Reason: Clarify information and typos.
