Old 30-Nov-2013, 2:41 AM   #4
fivehokies
Question Antenna height
Here is the report from 25'; I am not sure how to interpret the difference with the 5' report.
http://www.tvfool.com/?option=com_wr...46aeb88b81637f
I am not sure if the 5' is accurate or not. The RCA antenna is 5' off the ground, but my house is on a hill. It is much more than 5' above the street level if that makes sense.
I took advantage of the old DirecTV stand rather than put more holes in my brick. If it will make a significant difference, I can put up a higher stand.
What are your thoughts on filters or amplifiers? Only try them after experimenting with another antenna location?
Thanks so much for the help.
Steve
fivehokies is offline   Reply With Quote
