Don't be afraid to add a second FM trap.
If that fails to resolve the trouble, I would experiment with a High-VHF antenna that has better performance than the dipole you've got now. In the attic, you're starting at a disadvantage. Erring on the large side when selecting an antenna for an attic install is prudent in most cases, but even that may not work well in some attics. YMMV
I'd try either the Antennacraft Y10713 or Y5713... go big if it will fit. The UHF/VHF combiner on the C2V should do fine if you connect an alternate H-VHF antenna to it.
The same is true of UHF... If you're stuck in the attic for what ever reason, bigger may be 'enough better'.
