Home Depot and Lowes has all manner of Grounding hardware and connections and also has Copper Alloy wire that is very strong and long lasting is made for the purpose of grounding.
A Coax Ground Block can be installed at the antenna / antenna mounting and ground the coax and antenna mounting , with coax ground block installed on the antenna mounting.
Is best to run the ground wire to the electric service area at the the building and connect to the ground rod wire or actual ground rod.
However it is your choice to install a separate ground rod or use a separate ground rod that is already in place.
Reason: Clarify informtion and typos.
