Old 29-Nov-2013, 8:01 PM   #13
decaffeine
That is some good advice Teleview,
I have quad shield cable, compression connectors, and the proper tools to crimp them. That coax seal tape looks like some good stuff but I will probably use up the stuff I have. I have tons of silicone F4 tape and a big bottle of liquid tape.
I was looking into grounding. I know how to put in a grounding rod and run the wire but not sure how it connects to the antenna. Does it only go to the shield of the cable, or should I connect it to the mast too?
decaffeine is offline   Reply With Quote
