The channel I'm having problems with is 8.1/8.2/8.3. No pre amp and the splitter is just a cheap two way splitter cable company had left behind. Noticed this morn it was coming in weaker on the one tv that works good at night. I have antenna pointing in between the Atlanta stations and the 8 DTV to try and help get them both. I have another tv I would like to run the coax to. Would this need an amp-splitter or would it overload signal too much. No amp needed for the two tv setup for sure, maybe need a better splitter that's non powered, or rotate antenna some?
