The ANT751 and ANT751R = Resvised.
The revised version is retuned for a little better performance for the reduced number of channels of the UHF channels.
The UHF channels are now 14 thru 51.
We're 14 thru 69.
However for all pratical pouporses , it's splitting hairs as a improvement in reception ability.
Performance of the HBU11 is a little better then the ANT751.
Because of the Bowtie UHF reception element.
And has more active VHF high band elements.
However the performance improvement of the HBU11 , With Strong Local Signal Strengths , as compared to straight UHF reception elements , is also very close to , splitting hairs.
In a Weak signal strength reception situation the Bowtie type UHF reception element is better at receiving.
Longevitity of both antennas will be about the same.
Reason: Clarify information and typos.
