Old 15-Nov-2010, 8:40 PM   #1
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
PBS on Real Ch 24
I've recently made many changes to our OTA setup (new antenna, preamp, new RG6, shorter coax lines), and our TV reception is greatly improved.
I have an Antennas Direct 91XG about 30-ft in the air pointing about 74° (Magn).
Attached to that is a Channel Master CM7777 Titan2 VHF/UHF preamp.
These are connected with RG6 to a grounded mast with rain loops.
Once inside the house, the RG6 is grounded and fed into a 4-way splitter (living room, 2 bedrooms, and one terminated output).
The last good channel I get is KSLA (Real 17, Virtual 12, CBS, NM 21.3 dB).
What are my options for getting PBS at 74° with a NM of 13.4 dB? It comes in from time to time, but it is not dependable. We really want our PBS!
My TV Fool data is >> HERE << or you can simply reference the plot below:
~Joe
Avoid Sears Home Improvement!
jp2code is offline   Reply With Quote
