Old 29-Nov-2013, 9:58 AM   #5
StephanieS
Rfox20,
I was thinking about your post again tonight. I missed that FOX/WHNS at magnetic 200 you DO receive. That is an excellent catch due to WHNS' signal being -8.0 db according to your plot. Your antenna gain and preamp are working well together. Pulling out WYCW is even more impressive.
This is a wild approach, but if I were in your shoes I may go for a three antenna option. Sounds extreme, but keeping the HD8BX at magnetic 200 keeps FOX, PBS and NBC.
Then at magnetic 136 point an AntennaCraft C290 to grab CBS and likely NBC via W09AS again. PBS will also be available here as well.
Lastly, Antennacraft Y10-7-13 pointed at magnetic 220 for ABC WLOS.
I would run preamps on the HD8BX and Y10-7-13. The C290, might call for it, but I would try without first.
Each antenna would drop it's own dedicated coax run to A/B/C switch. A usable one might be this:
http://www.mcmelectronics.com/produc...-1490-/33-1490
In this arrangement you'd add CBS high definition (as opposed to SD on 62.2), Keep FOX, Keep PBS, strengthen reception of NBC and add ABC.
It's kind of nutty, but when you have a variety of signals in several directions and special needs for each set of signals, you can see how it gets intense pretty quickly.
It would actually be fun though, doing a 3 antenna set up, just for the challenge of pulling out all the signals you want.
Of course though at the end of the day, just adding the Y10-7-13 may be the easiest. heh
Regards,
SS
