Old 28-Nov-2013, 8:34 PM   #4
StephanieS
Yes. You can do that if you are satisfied with the HD8BX.
When mounting the Y10-7-13 and aiming at magnetic 220 for WLOS, make sure it is at least 3' below (or above) your other antenna. Three to five feet separation is the goal.
How long are your coax run(s)? I would test Y10-7-13 after mounting by running coax unamplified into one TV to test reception. Then I would I add the amplifier in line and see if your results improve. Then finally, test with the chain fully set up. That is: antenna, coax, (preamp), (coax), (preamp power supply), A/B Switch, coax, (splitter), (coax), TV. Parenthesis indicate items in your chain with the use of the preamp. Being able to compare and contrast is good so you know your antenna performance in baseline scenarios and with your chain fully operational as well if there are problems at what stage issues are occuring.
Edit: Regarding only receiving PBS at magnetic 136. That makes sense. Two of the other translators are VHF (RF 2 and RF 9). This is likely the same issue you have with WLOS and the HD8BX. The antenna's VHF receiving ability is pretty much reserved for those in the excellent to good range. Those mentioned translators are in the moderate category. Thus, for reception of CBS and NBC's translators you need an antenna with stronger 2-13 VHF support in conjunction with UHF support..
Regards,
SS
Originally Posted by rfox20 View Post
I have tried to point my current setup a mag 136 and was only able to get pbs. So how about doing the separate Antennacraft Y10-7-13 H-VHF antenna with the RCA Preamp TVPRAMP1R to get wlos which gives my the networks ? Following up with the a/b switch as a setup.
