Old 28-Nov-2013, 6:13 AM   #3
A Simple reception situation.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North North West install a , Channel Master CM5016 , All channel antenna aimed at about 335 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
A antenna system amplifier is not required for 1 or 2 Tv's connected.
For 2 Tv' connected use a , Holland Electronics , HFS-2D , 2 way splitter.
Buy the , HFS splitter at , www.solidsignal.com
Winegard , DS3000 , J pole type antenna mount works Ok with the CM5016 antenna. www.winegarddirect.com .
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2219) , ronard(2224) .
Buy the ronard antenna mounts at , www.solidsignal.com , by typing , ronard (x) , in the solidsignal search box or buy from , www.ronard.com .
www.solidsignal.com
www.amazon.com
www.channelmasterstore.com
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception and so do buildings and other obstructions including your own roof and building in the directions of reception.
Some and not all Negative Effects are
Absorbing , Blocking , Reception
Multi-Path Reflections Bouncing all around.
The Best Pratice is to install the CM5016 antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
Last edited by teleview; 28-Nov-2013 at 6:21 AM. Reason: Clarify information and typos.
