Consider an all channel antenna such as the Channel Master CM-3016 or CM-3018... Or the Antennacraft HD-850 or HD-1200.
If you have long cable runs or are splitting to several TVs, the Winegard HD7084P would be a premium solution, though not overkill.
All of these antennas will do best if mounted above the roof, clear of obstructions. An amplifier should be avoided unless you have unusually long cable runs or you're splitting many ways. Point the antenna north and slightly west to start, fine tune the aim before tightening the clamps in their final position.
