Old 27-Nov-2013, 5:05 PM   #6
Trees or no trees.
The -->Main Group<-- of Tv stations that you will like to receive are to the , North North East.
Aiming the antenna to the , south south east , will make for , A Lot Less , reception of the , Main Group of Tv stations to the , North North East.
The Tv stations to the , south south east , strong signal strength , the Tv stations to the , North North East , strong to Very Weak Signal Strength.
--->Aim the antenna at about 20 degree magnetic compass direction.<---
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
As always , the starting antenna aim direction is the --> strating antenna aim direction , the antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter .
Last edited by teleview; 27-Nov-2013 at 5:11 PM. Reason: Clarify information and typos.
