The Best Way to receive broadcast Tv witha Tv antenna is to have the antenna clear of obstructions in the directions of reception.
If the tower provides better reception that is more clear of obstructions in the directions of reception , then Yes install the ANT751/R on the tower.
Yes RG11 has less signal loss , so Yes use the RG11.
RG6 is also Ok to use.
How many Tv's -are/will be- connected??
Test reception without a amplifier.
How many Tv's are/will be connected??
If you will like to receive the Canada Tv stations , and USA Tv stations.
And also Reach Out for the USA Tv stations that are in the Red reception zone that are , 78 plus miles away.
Install a Winegard HD7698P antenna , not the ANT751.
I can not say that the USA Tv stations in the Red reception zone will be reliably received.
It is a 'Test' the reception situation.
