An omni may work, but a directional antenna like the FM-6 mounted outside would be a better choice if those 2 stations are your main goal. Are you trying to receive the HD signal of either station?
The attic may well if the FM-6 is used, but really hard to tell without trying. You could always try the attic first & see if you can receive satisfactory results.
What tuners are you using for FM?
