Thread: FM reception
Old 27-Nov-2013, 11:30 AM   #1
oakleyhoma
FM reception
Hi all, need some help. Here is my report http://www.fmfool.com/index.php?opti...pper&Itemid=29 . This would be exterior antenna, mounted on cinder block fireplace at or near the roof peak. Two separate runs to first floor and basement, longest run probably about 34 feet. In particular, I want good reception for call signs WNCW and WETS-FM. I don't want more than one antenna: will an omnidirectional work? What coaxial cable would be best and what shielding? What do I need other than an antenna, coax, and connectors? How much better would this exterior antenna be than doing slightly longer runs to an attic antenna?
Thank you.
oakleyhoma is offline   Reply With Quote
