Old 27-Nov-2013, 8:01 AM   #6
CIII has more then one transmitter.
At your location is also CIII on UHF channel 14.
So no requirement to receive the channel 6 CIII.
My recommendations are based on the Current and Pending Applications Included and extensive - ongoing - research that goes way beyond the current and pending applications.
Your location is a Simple Reception Situation.
For reception of the Canada Digital Broadcast Tv stations/channels and USA Digital Broadcast Tv stations/channels , WNPI-DT PBS , WCFE-DT PBS , WNYF-CD FOX and CBS , www.en.wikipedia.org/wiki/WNYF-CD .
Install a ANT751 antenna above the peak of the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , north west , south west , south , south east .
Aim the ANT751 antenna at about 168 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
A antenna system amplifier is not required for 1 or 2 Tv's connected.
Here are some place to buy antennas and etc. .
www.saveandreplay.com
www.trentondistributors.com
www.amazon.ca
www.amazon.com
www.solidsignal.com
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu Because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels .
Scan for channels.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
The Best Pratice is to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Last edited by teleview; 27-Nov-2013 at 8:06 AM. Reason: Clarify information and typos.
